Analyzing U-Bolt Connection to Timber Pile
I want to see if I could use a large U-bolt to attach some diagonal bracing to a timber pile to reduce cost of underwater construction. The diagonal brace could deliver both tension and compressive forces. The way I see it the horizontal componenet of the tension or compression force will result in bearing of bolt on timber or wood to wood bearing of brace to pile. The lateral component of the force I think would be more of a factor of friction of the bolt on the pile unless you consider the u-bolts rack a little and now your back to bearing. My gut tells me the connection would have enough capacity but I want to quantify in it in some rational method...any thoughts or help appreciated.
RE: Analyzing U-Bolt Connection to Timber Pile
I don't think that is a good idea - esp under water where the water will act like a lubricant.
-Robert Miller, E.I.T.
KPA Structural Engineers
