Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Keep up the good work - excellent site - i'd been looking for something like this for ages !..."
Geography
yassinemzili (Civil/Environmental)
8 Jun 11 6:36
what's the distance between pole support made frome steel(I-beam) and a sprinkler?
I found in NFPA 13 distances between Suspended or Floor-Mounted obstruction but not pole support that are mounted in the floor and in contacte with the roof.
skdesigner (Mechanical)
8 Jun 11 10:08
Might you be referring to a column?
If that is the case, see NFPA 13 2007 Figure 8.6.5.2.1.3.  This is called the "3 times rule".  Space your sprinkler 3 times the largest dimension of the column away from it's edge, up to 24".
8 Jun 11 11:04
I draw somting in "paint" take a look at it ant tell me if it's wrong!
pipesnpumps (Mechanical)
9 Jun 11 0:20
You didn't draw the size of the column.
If the column is say  200 mm by 300 mm, then taking the largest dimension that is 3x300= 900 mm.  However, the max. required is 610 mm, so put the sprinkler at least 610 mm away.
Real world knowledge doesn't fall out of the sky on a parachute, but rather is gained in small increments during moments of panic or curiosity.
Close Box
Join Eng-Tips® Today!
Join Us             Close
