CHANGE IN PRE-HEAT
CHANGE IN PRE-HEAT
Hi all,
There is ongoing welding in our pipe shop. Approx.the ambient temperature is 24 C outside and much more inside the shop. The thickness of the pipe is 32mm. Per ASME SEC IX (Table 303.1.1) the recommended temp is 80 C, but if the ambient temp is below 0 C, recommendations become requirements ( QW-330.1.1). Everything is fine up to that point. My concern is; Min. pre-heat temperature is stated 80C on our WPS, and ASME lets a 55 C decrease in the pre heat temperature without re-qualification (QW 406.1), could you please clearify me if it is acceptable to start the welding in the shop temperature which is around 28-29 C instead of heating it up to 80C ?
Best Regards
Kaan
Best Regards
Kaan
RE: CHANGE IN PRE-HEAT
Your WPS requires the 80°C preheat, not the Code. Fix the WPS, or use the 80°C preheat on the WPS. This revision, if made, will not require a new PQR -- per QW-406.1.
I checked the PQR which is impact tested , per our pWPS used in PQR, also the preheat temp. is specified 80 C. Can I prepare a new WPS / revise without pre-heat by using this PQR?
Review the variables per QW 406 in Sec IX for the applicable process. You're probably going to be restricted to a max change of 55 C.
Actually you can't decrease preheat > 100F ( 55C ) whether or not impact testing applies. ( Essential variable)
If impact testing applies you can't increase interpass ( or preheat that exceeds interpass temp qualified) > 100 F ( 55 C ).
( Supplementary essential variable)
Guys, you re really appreciated for your helps.
Cheers
