Cp Calculation for Beam analysis
If Lb falls inbetween Lp and Lr the Cb value is required to find the bending moment. Suppose the applied load to the beam is unsymmetric. I have a simple span with an off center point load.
Is the Cb = 12.5M/(2.5M+3Ma+4Mb+3Mc)Rm equation still valid or should I just rely on the AISC available moment charts.
Thanks guys!
Thanks guys!
RE: Cp Calculation for Beam analysis
What Cb allows you to do is shift the entire LTB moment curve "up", but never beyond the plastic moment capacity.
