cause effect question ("not open" and "close" difference)
There is Low pressure hopper (above), and high pressure hopper (below), with their XV-00A(loading inlet valve), XV-00B (vent valve).
As start of the transfer, open XV-00A to allow particle to enter the low pressure hopper, then transport gas vent to collection header.
And, XV-00C, XV-00D are transfer valves from LP hopper to HP hopper.
Could you please explain why ZSO-00C, ZSO-00D is described as "not open" instead of close when permissive action required (attached in the post)?
could you please help me out?
Thank you for your help.
RE: cause effect question ("not open" and "close" difference)
While 'not open' is arguably the same as 'not closed' in a two switch scenario, the 'not open' label would be applied according to the fail safe or operator interest.
