PE Exam - Engagement Form Help
I'm working on filling in all the forms that are required for taking the PE exam in California. I'm thoroughly confused about some of the stuff though. My main concern is Part A of the Engagement Record form http://www.pels.ca.gov/pubs/forms/perefsfrm.pdf where it says "Level of Responsibility," what do I put here? What are acceptable answers?
Also, I worked with 4 PEs (per requirements), however I didn't work with each in a nice linear fashion, I worked with PE 1, then PE 2, then PE 1 again, then PE 3, etc... I'm wondering if for each restart I need to give the PE a new engagement form, or if the "total time worked in months" will let the reviewing folks know I had other engagements during the first start and the last end dates...
Thoughts?
Thoughts?
RE: PE Exam - Engagement Form Help
You will probably get better responses over at www.engineerboards.com
good luck.
-Dustin
Professional Engineer
Pretty good with SolidWorks
You want things like:
Analysis of this this type of system. Sized motors/brakes for this or that.
Drafting type experience isn't "qualifying experience", so don't highlight that.
-Dustin
(2B)+(2B)' ?
