How to change the wizard to SI unit?
I am working on a new project which are using SI unit.
However, the wizard always use US unit as default when I creat a new vessel. Yes, I can change all of them to SI unit after the wizard. However, Tom, Do you know how to change unit during the wizard? It will make my life easy.
RE: How to change the wizard to SI unit?
action tab
set mode options
units    SI
I try F7 to mode options.
It does not work for me.
SJEC,
On the first screen of the vessel wizard there is an option to select the units (U.S, SI, or MKS). It is located in the middle/bottom of the dialog.
Matt
MattHeilandt
Which window are you talking about?
Could you kindly check my attachement?
Please note, the right bottom the unit has been setup to SI.
