Open a draft from an assembly
Is there a way to open a draft of an assembly by right-clicking or some other way instead of just going to open and finding the draft. For instance in SolidWorks if you right-click on a part or assembly it gives you the option to open the drawing from th menu.
thanks!
RE: Open a draft from an assembly
Kenat is correct, Solid Edge works differently in this regard. We use "where-used" to find drafts. Fortunately with Insight Server the search process is relatively fast.
Solid Edge ST3 MP5 on WinXP x64
Insight Server on Win2008 R2 & SQL 2008 R2 x64
SharePoint 3.0 x64
thanks for the info!
I have the attached the Software.
AFAIK Works with V20, ST1, ST2 and ST3.
The Software works as an Addin. It could be start with a right mouse click on a Part in a assembly or in the Part enviroment.
The SW is like it is. No Warranty.
Suggestions to improve the solutions are welcome :)
