Mass of an assembly
Mass of an assembly
Hi All,
I am trying to display the total weight of my assembly on a draft but I cannot get the mass to show up with anything but 0.0LBM. I have went into the assembly properties and used %{Mass|R1}as the Name and 0.28298507824 lbm/in^3 as the Value. Am I doing something wrong? All of my parts do have a material applied to them.
Thanks!
Joel
Thanks!
Joel
RE: Mass of an assembly
So %{Mass|R1} is what you should use for the property text ON THE DRAWING, not in the assembly model. If you are not sure how to do this let us know.
You appear to have added a property called %{Mass|R1} to the assembly model - delete it if you have.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Does it show 0 or does it show an error?
bc.
Quadro FX4600.
Try changing the property text to %{Mass/@4|R1} - this will force it to 4dp.
bc.
Quadro FX4600.
