negative pressure created by column of liquid.
I am trying to calculate negative pressure which can be created by column of seawater with a height of 3 meters. The pipe configuration is basically inverted U-tube where u-bend located at elevation of 3 meters. Pipe is seawater filled and is open ended with atmospheric pressure at the open end. Could anybody please advice can I calculate negative pressure or suggest book where I can find appropriate calculation.
RE: negative pressure created by column of liquid.
Best regards
Morten
