Station Configuration Question
Hi I have a question regarding a station configuration arrangement as seen in the attachment (sorry for the crude drawing). It involves two separate Tx lines supplying a a three winding transformer, which in turn supply two separate buses on both sides (and then of course, the individual feeders). I understand the concept of redundancy on which this configuration is derived, however, am I correct in saying a very very large circulating current would on each individual bus if the two voltages on either side were not exactly the same?
From my understanding, tapping operations are not quick. Thus, if the voltage on one Tx line suddenly dropped or rose, the two ends of the bus would be at a different potential for seconds.
Is there some sort of strict voltage regulating mechanism in place with these types of stations or am I missing something on a more fundamental level?
RE: Station Configuration Question
If the system really is configured as you show then yes, there could be very large circulating currents. Overcurrent protection would need to be directional, or a zone protection (bus differential) scheme implemented, otherwise you don't have increased security, you just have a bigger bang when something goes wrong.
