MRI Equipment - Elevated Slab
I am currently dealing with a situation where a client wants to locate an MRI equipment on the 3rd floor of a steel framed building.
The floor system consists of 2" metal deck + 3.5" concrete topping supported by W24 beams. The deck spans vary from 7'6" to 9'-6". The unit will finally be located straddling a W24x103 beam.
The unit is 14,000 lb with loads distributed through 4 legs (7" diameter). The legs are placed on a 36" x 30" square.
I have checked the beams and its connection to work, but I am having trouble getting the deck to work when the unit will be wheeled into place. There is a open terrace on which the unit will be delivered. The unit will need to move through at least 3 bays (with the largest span on 9'6") to its final location.
I am trying the metal deck point load distribution calculations (from SDI and NJB) but I find it difficult to justify FOUR 3.5k loads 3' from each other acting as individual point loads as opposed to a single 14k load. What do you guys think?
The building is currently partly occupied. I am not sure what is happening with the second floor.
RE: MRI Equipment - Elevated Slab
ANY FOOL CAN DESIGN A STRUCTURE. IT TAKES AN ENGINEER TO DESIGN A CONNECTION."
BA
Is that based on prior experience? If so what plate thickness and plate width would you recommend?
Will this plate be kind of a "carpet" for the unit to roll on?
Michael.
Timing has a lot to do with the outcome of a rain dance.
I once had to do an entire schematic drawing of how this was to be laid out for the entire 200ft journey down a 1930s RC floor slab in an old VA. Fun...
BA
