intel visual fortran 11.1.065 abaqus verificaton
I found in Forums these :
4. Verify the settings before.
intel fortran 11.1 no direct reference to bin folder under the ifortsvars.bat. Right-click the Start menu Abaqus Verification, select Properties, a column in the target by adding the following:
32-bit machine to add: "C: \ Program Files \ Intel \ Compiler \ 11.1 \ 065 \ bin \ ia32 \ ifortvars_ia32.bat" & &. Note that & & followed by a space, and the path to use up half-width expansion of the double quotes.
64-bit machine to add: "C: \ Program Files \ Intel \ Compiler \ 11.1 \ 065 \ bin \ ia32_intel64 \ ifortvars_ia32_intel64.bat" & &.
My goal of 32-bit machine the last column of the content is "C: \ Program Files \ Intel \ Compiler \ 11.1 \ 065 \ bin \ ia32 \ ifortvars_ia32.bat" & & C: \ SIMULIA \ Abaqus \ Commands \ abq6101.bat-verify -all-log & & notepad.exe verify.log | | notepad.exe verify.log
I added my 64 Bit Computer : "C:\ Program Files (x86) \ Intel \ Compiler \ 11.1 \ 065 \ bin \ intel64 \ ifortvars_intel64.bat" &&
But there is a error: The name 'C:\ Program Files (x86) \ Intel \ Compiler \ 11.1 \ 065 \ bin \ intel64 \ ifortvars_intel64.bat' specified in the Target box is nod valid. Make sure the path and file name are correct.
I didn't understand this sentence in forum exactly: and the path to use up half-width expansion of the double quotes.
What can I do now? and are there anything to Abaqus Command in the use of subroutines UMAT because I have a problem: Problem during compilation - ifort.exe not found in PATH.
RE: intel visual fortran 11.1.065 abaqus verificaton
you have to edit the system PATH variable and add the path
here is more information
http://www
