Is it possible to compare Random response data with Frequency Response
i have two sets of data: 1) Random PSD g^2/hz data from a test we ran and 2)  frequency response data from the manufacturer (i.e. acceleration versus frequeny). Is it possible to compare these two to see if over testing was done?
RE: Is it possible to compare Random response data with Frequency Response
Quote:
frequency response data...
would normally be output/input vs. frequency.  Are you sure about what you have in 2) above?
I mean accel versus frequency.  I obtained this data by taking FFT of time domain in-situ manufacturer data from a test where he mounted accels to hard points on the chassis of vehicle.
So now i have two curves.  1)freq./g**2 from random test we ran.  2) freq/g curve from vendor.
Now to compare the two do I just look at what happens at resonance of the part mounted to the chassis (which i make)  and use Miles equation?  Then see which gives the higher loading?
I am sure there I cannot just make a head to head comparison but only look at resonance to see if there was an overtest situation.
