Burst command not working...
I am on AutoCAD 2002. I was able to migrate the express tools from 2000 and they worked fine. This was years ago.
Now all of a sudden the "burst" command does not work. Also the same command from the drop down express menu "explode atributes to text" does not work.
Here is what I've been getting:
Command: burst
Select objects: 1 found
Select objects:
None found.
Command:
I'll select the block, enter then nothing.
Anyone experience this and found a solution.
Thanks in advance,
Spike
Command: burst
Select objects:
None found.
Command:
Thanks in advance,
Spike
RE: Burst command not working...
Audit the file
save, open using Recover (not open)
try again.
What is Regaps? I can't seem to find it.
chicopee:
Tried to reinstall the tools to no avail. Still on Windows XP.
