Chlorine service valves' standards
Are there any standards that deal with valves or other pressure containing parts for chlorine applications?
Thanks in advance
RE: Chlorine service valves' standards
Hi Pitg,
Applicable standard: CHLORINE INSTITUTE PAMPHLET 6 CLASS II.
Chlorine Institute Pamphlet 6: Piping Systems for Dry Chlorine
Chlorine Institue / 01-Apr-1993.
Contains information on selected pipe, valves, & fittings suitable for use with dry chlorine (gas or liquid) within the range of -150F & -300F.
Please refer the below link and Flow serve supplies valve for chlorine service.
http://www.chlorineinstitute.org/Bookstore/ProductDetail.cfm?ItemNumber=2536
Thanks gafoorkti
Pitg,
     also Euro Chlor issues technical pubblications (including papers, presentations, recommendations, guidelines and best practices, etc...).
     See  http://www.eurochlor.org/safety
Hope this helps,        'NGL
___________________________________
