Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is awesome!...Things I have been trying to figure out for weeks, I got the answer in hours!..."
Geography
designdummy (Industrial)
3 Jun 11 10:52
I am trying to install WF4.0 (datecode M010) on a new Windows 7 64 bit machine. A major issue...ProE won't run.
I have the licence pack installed and have gone through all install steps. When I try to run ProE from the desktop icon, or the Pro E .exe file, I get an error message as follows:
ERROR: Unable to launch ProEngineer because no valid configuration (.psf) files were found. Please run "ptcsetup" from you installation "bin" directory and create a PTC startup file. This is needed for ProEngineer to launch successfully.
I have done this, but get no results
My maintenance contract expired 3 years ago and do not have the money to reactivate it, so I'm stuck with this version.
Does anyone out there have any suggestions for me to get this up and running? Any help you can give is much appreciated.
Thanks for your help.
looslib (Mechanical)
3 Jun 11 11:50
Is your Pro/E version for 32-bit or 64-bit OS?
Win7 does allow you to run a virtual XP machine that you may need to do in order to run WF4.
I found my WF4M100 CDs and they do not list Win7 on them, WF4M150 does.
Look in the <loadpoint>/bin folder for a .psf file or a .bat file. These would be created PTCSETUP.
Ben Loosli
hydromech (Mechanical)
3 Jun 11 11:51
It is assumed that you have the 64Bit version of Pro Engineer..?
3 Jun 11 12:56
Thanks for your response.
This version I am trying to install is a 32 bit. Date code M010 (if that helps)
I can run the XP virtual desktop but have read that it completely bogs down the system with graphicly intense programs (read ProE)
Both .psf and .bat files are present in the bin folder. I have tried to run these and nothing happens.
Any suggestions?
3 Jun 11 14:21
Did you install WF4 in the default location: c:\Program Files(x86)\ptc? There have been isues with PTC products and spaces in the pathname. It may not like the parenthesis, either.
Try reinstaling it to c:\PTC. (You can just move the PTC folder up to the root level and then rerun PTCSETUP.)
Ben Loosli
Close Box
Join Eng-Tips® Today!
Join Us             Close
