Looking for a Coarse Steel Grit Blasting vender?????
I need to find a company that can perform a steel grit blast on some Ø0.600" O.D. X 6.00" LG shafts.  The spec for the grit is SAE G40 angular steel grit, and the company must be able to supply certification for the blasting opperation. I am located in Michigan, if anyone knows of a reliable company please let me know asap!!! Thanks
RE: Looking for a Coarse Steel Grit Blasting vender?????
I don't know of any job shops in your area that can do the blasting.  I would go about by checking with a manufacturer of the grit like ErvIn Industries to give you some leads.  If that don't work call Metal improvement to see if they can handle your job.
Next in line I would contact the suppliers of the blasting equipment and see if they can help.
and last but not least Ask.
http://www.ervinindustries.com/Default.html
http://www.ervinindustries.com/DocumentLibrary/ShotCard/ShotCard.pdf
http://www.metalimprovement.com/index.php?gclid=CIKEsdn9oqkCFYx95Qod3Erbtw
http://www.wheelabratorgroup.com/sites/wheelabrator/content/equipment/airblast__wetblast.aspx
http://www.pangborngroup.com/Brands/Pangborn.aspx
http://wetblasting.com/abrasive-blasting-home.aspx
