transformer radiation
I'm building a moly glass furnace that requires a 40kva transformer. The transformer might need to be inside my building.
How do I determine emf...radiation levels from the transformer and the safety protocols...distance from, shielding, etc.
Thanks,Virgil
Thanks,Virgil
RE: transformer radiation
A calibrated antenna plus a calibrated receiver/spectrum analyzer for HF radiation and a triaxial VLF meter for low frequency magnetic fields. Hire an EMC consultant to do the measurements if you do don have the necessary knowledge.
Why do you bother? Are there sensitive equpment nearby? If it is about animals or humans, you can forget about any problems. Any transformer made with modern methods have neglible magnetic leakage even without any encapsulation.
Gunnar Englund
www.gke.org
If it is,then of course the high frequency content of magnetic field from transformer/cables will be higher than for a transformer feeding a sinusoidal load. But whether it will be a problem, beats me.
(2B)+(2B)' ?
