Question on steel fatigue
Does anyone know, or has a reference to, how the endurance limit varies with minimum stress in a steel fatigue situation ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Question on steel fatigue
http
endurance limit assumes minimum stress = 0. if you've got cycle max > EL and cycle min = (cycle max - EL) (ie the stress cycle 0-EL-0 is shifted up) then you're going to be very close to infinite life. there is a stress ratio effect but generally R > 0 is beneficial.
