True Involute Spur Gear Generator
We often use a gear driving a series of pins to move our equipment. I searched high and low for an affordable software package to help use generate involute profiles for this and stumbled across this fantastic gear generator and wanted to share:
http://woodgears.ca/gear/index.html
It has a fun demo to try, definitely worth a download if just to fiddle with it.
It's mostly 'geared' towards wood craftsmen who would print out and trace the gears but it will spit out a DXF which can be CNC cut. It does output the dxf as a series of short lines, so I like to clean it up in CAD by stitching them together with a spline.
I'm not advertising this, I just thought it might be useful for anyone looking for an inexpensive lower precision involute gear generator!
-Kevin
RE: True Involute Spur Gear Generator
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
