electronegativity of aluminum and steel
Hi all,
I'm not an expert in corrosion and electronegativity, but I've got a test setup that I made for my client. the fixture is 316 steel and to test the setup my client said "just have some aluminum caps made."
Not thinking too much about it, I had them made. We were gonna use the test fixture for 1-2 days, and I didn't think anything of electronegativity between the steel and aluminum. After 24 hours of letting tap water sit in side the chamber, the caps had a white gunk on it, and the dumped water had particles floating inside. I don't know if it's from the brand new fixture that no one looked inside of, or from the tap water.
My question is, how quickly will a galvanic reaction between aluminum, 316 steel and tap water happen? I'm trying to determine if new steel caps need to be made, or if it might have been dirty water or a dirty fixture.
Thanks!
Thanks!
RE: electronegativity of aluminum and steel
The steel fixture is about 7" long and 1.5" diameter, the aluminum caps cover the end of the tube, so the exposed diameter is 1.5".
The aluminum is the anode then, isn't it. hmm.
The temp is room temp, and the tap water is typical LA water. When you mention the area part, now I'm thinking that the aluminum was a bad choice...
