Export and assembly as a IGES, need individual parts
Hi All,
I am looking to take a large assembly and export it as an IGES file, but also it needs to export out each individual part of the assembly. Cna this be done?
Thanks!
Joel
RE: Export and assembly as a IGES, need individual parts
Why iges for a solid model?
Better with Parasolid or STEP.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
it needs to be opened in Inventor when saved out. And it needs to be an assembly when it imported into Inventor instead of one massive solid.
I did a test with saving the assembly out as a parasolid and then imported it back into Solid Edge. I selected an assembly and then it created all of the parts as well as the assembly. is this the corect way to do it?
That's how it works - each part is saved as a new model, regardless of how many times its used.
How it goes into Inventor will depend on how Inventor deals with Parasolids.
I would give a STEP and Parasolid, that way you should be covered.
bc.
Quadro FX4600.
Parasolid worked perfectly for the conversion. Thanks again for your help! You are my Solid Edge Master!! lol...
