Phenolic tube ducts
Phenolic tube ducts
Hi guys,
I'm currently manufacturing some tube ducts out of glass phenolic. The lay up is fine as the mould is split in half. Once the duct is joined we then have to pull through a rubber intensifier. We are have some trouble getting this through efficiently and removing it effectively after curing. Sometimes the intensifier is damaged pulling it against the cured glass. Any tips that could help me?
Cheers
Cheers
RE: Phenolic tube ducts
Mike Halloran
Pembroke Pines, FL, USA
I can't say that I've ever heard that saying before. Can you elaborate?
From your context, I took 'intensifier' to mean a tube of some sort that you pressurize in order to compress the wet laminate.
If you're just using a solid rubber slug, consider making it hollow and pressurizing it during cure.
Then after cure, you can deflate it, and pull a vacuum if you need to shrink it further.
Mike Halloran
I am using a hollow rubber tube intensifier that gets pulled through, I then apply an outer bag with a bag down the centre of the rubber intensifier.
Assuming you meant 'sharp', yes, phenolic/glass leaves super-nasty sharp edges and spikes where it doesn't get fully compacted.
... which might be resolved if you pressurized the rubber tube a little during cure.
Or maybe I am misunderstanding the problem.
Mike Halloran
