reading Abaqus history output data: keyError
thread799-274802: abaqus historyOutput
Hi, I am trying to get the history output for the pressure (and displacements) in a one dimensional consolidation problem. I implement the problem on an input file really similar to the Abaqus example input file 'terzaghi_cpe8p.inp' for the Terzaghi consolidation benchmark problem. I am trying to get the output using a python script, as described in the paragraph 8.5.8 of the scripting users manual.
My python code looks like:
from odbAccess import *
from abaqusConstants import *
# Open database
odb = openOdb(path='3.odb')
# display the part instances in the output database
for instanceName in odb.rootAssembly.instances.keys():
    print 'instanceName: ', instanceName
# assign variables to the three steps of consolidation
step2 = odb.steps['Step-2']
print 'history keyes: ', step2.historyRegions.keys()
# define the node on which pressure will be recorded
nodal_pressure2 = step2.historyRegions['Node PART-1-1.1']
# define variables on which to store the pressure
presData2 = nodal_pressure2.historyOutputs['POR'].data
# define the output file for the nodal pressure
pressureFile = open('nodePressure.dat','w')
for time, pressure2 in presData2:
    pressureFile.write('%10.4E   %10.4E\n' % (time, pressure2))
pressureFile.close()
I run this code and I get the following:
instanceName:  PART-1-1
history keyes:  []
Traceback (most recent call last):
  File "post.py", line 17, in <module>
KeyError: 'Node PART-1-1.1'
In my input file I do not define any part. Is this related to the error message?
If anyone help with this error message I would greatly appreciate it!
Thank you very much in advance,
Andi
RE: reading Abaqus history output data: keyError
It seems that this one was easy to fix, I added the specific lines on the input file:
*Output, history, frequency=1
*node output, nset=LEFTBOUNDARY
  POR, U2
Cheers!
