Ground Freezing - Insulation Of Concrete
I am looking at brine freezing saturated ground in a ring around a tunnel in order to remove some damaged concrete rings. I intend to replace the damaged rings with an in-situ concrete ring. Can anyone advise me as to how I can insulate the wet concrete from the freezing effects of a ground at minus thirty degrees so that the concrete will cure and the heat of hydration does not begin to melt the ice wall?
Ginger
Ginger
