Obscure FEMAP Errors
I've been trying to solve the static analysis example of the assembly with the "contact" connection property provided in the femap help system. I have solved this before with success, but below is the list of obscure errors femap throws at me when I try to solve it this time.
NX Nastran started  Wed Jun  1 12:27:23 EDT 2011
 12:27:23  Beginning Analysis
 12:27:23  NX NASTRAN Authorization Information - System Attributes
 12:27:23  --------------------------------------------------------
 12:27:23  Model: Intel(R) Core(TM) i7-2600K CPU @
 12:27:23  Machine: Intel64 Family 6 Model 42 Steppi
 12:27:23  OS: Windows XP
 12:27:23  Version: 6.1 (Build 7601)
 12:27:23  License File(s): 28000@LocalHost
 12:27:23  The FEMAP dll Search String is c:\femap931\auth_64_*.dll .
 12:27:23  Found the FEMAP authorization dll auth_64_93.dll
 12:27:23  Loading FEMAP Authorization dll auth_64_93.dll
 12:27:24  NX NASTRAN Authorization Information - Checkout Successful
 12:27:24  ----------------------------------------------------------
 12:27:24  License for module NX Nastran Basic - FEMAP Desktop  checked out successfully
 12:27:24  Analysis started.
 12:27:24  Geometry access/verification to CAD part initiated (if needed).
 12:27:24  Geometry access/verification to CAD part successfully completed (if needed).
 12:27:24  Finite element model generation started.
 12:27:25  Finite element model generated 100110 degrees of freedom.
 12:27:25  Finite element model generation successfully completed.
 12:27:25  Application of Loads and Boundary Conditions to the finite element model started.
 12:27:25  Application of Loads and Boundary Conditions to the finite element model successfully completed.
 12:27:25  MAIN: "Access violation" (C0000005) exception encountered.
 12:27:25  MAIN: For reference, A(MAINAL)   =           401074, A(/SYSTEM/) =          2034EC0
 12:27:25  MAIN:                A(/XNSTRN/) =          5790040
 12:27:25  MAIN: Exception occurred at address 000000000055CAB7.
 12:27:25  MAIN: Program attempted to access data at location 0000000102F3A23C.
 12:27:25  MAIN: Context Flags 0010005F
 12:27:26  34509 records read from JID file "c:/users/udayraj/desktop/femap asy/model002.dat"
 12:27:26  NSEXIT: EXIT(20)
 12:27:26  Analysis complete  -20
20
Real:        2.338 seconds ( 0:00:02.338)
User:        1.294 seconds ( 0:00:01.294)
Sys:         0.358 seconds ( 0:00:00.358)
NX Nastran finished Wed Jun  1 12:27:26 EDT 2011
I use femap regularly, and most of the time it works fine, but every now and again I get these errors even if the setup seems correct no matter how many times I check it and redo it.
Can someone explain to me what might be going on here? I'd appreciate some help.
RE: Obscure FEMAP Errors
Hello!,
You show us the content of LOG file, but also the *.F06 file is welcome. Make sure you have write permissions in the directory "c:/users/udayraj/desktop/femap asy/".
Try to create a new subdirectoy at the root level, say D:\WORK and copy your FEMAP file there and run the model.
Also, check the NX NASTRAN RC file nast7.rcf, make sure the variable SDIR is correctly setup.
Check if any virus is installed in your system. Good luck!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
