Thermal expansion coefficient input- user defined material
How can one find the value that should be inserted in the temp input field to define the thermal behavior of a material (say 15128 steel, i.e. Cr-Mo-V, Czech norm CSN 415128-86), knowing the S.I. value of the thermal expansion coefficient (at 550 deg C - 14.85*10^6 1/K - norm value)?
Thank you,
Codrut
Thank you,
Codrut
RE: Thermal expansion coefficient input- user defined material
(This is explained in the "Help Text".)
Richard Ay
Intergraph CAS
