Copy projects and rename parts / drawing without loosing references
Hi, I'm new in SolidWorks and I have to copy a complex project and have to rename all drawings and parts. What is the easiest way to do this without loosing all references and links?
Thanks a lot!!!
VSCMDE
Thanks a lot!!!
VSCMDE
RE: Copy projects and rename parts / drawing without loosing references
Your method worked because all of your files are in a single folder.
-Dustin
Professional Engineer
Pretty good with SolidWorks
Pack and Go is available from the File menu.
I have used Pack and Go before, but for some reason today it seems to lock up when I select the drawings if I am in Flat View. Anyone else have that issue?
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
