IN-CAVED LOGO on CURVED SURFACE
I need to build an in-caved logo on a curved surface. I know how to make a raised logo on a curved surface. But how to carve out a 1 mm deep logo on a curved surface, which is created using a loft? The bottom surface of the logo should have the same curvature as the top surface.
I greatly appreciate your help!
RE: IN-CAVED LOGO on CURVED SURFACE
Make the logo sketch on a plane above the surface, then extrude-cut toward the surface and use the "offset from surface" selection.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Or use the Wrap tool with the Deboss (I hate that term) option.
Thank you so much!
