Revamp an old chiller
I have a 150 Tr Chiller made by Dunham-Bush. Condenser and evaporator are in the end of life and I need to replace both very soon. I don't have detailed dwgs for both and it looks like what has remained from the manufacturer is not able to locate any detailed drawing.
I am looking for a Golf based engineering office that can perform a reverse engineering and provide detailed drawings for both vessels.
RE: Revamp an old chiller
Also, if the evap and cond are poked, why would you think the old compressor is worth the exercise?
Thanks for your reply. We are actually evaluating 3 other alternatives as well. A completely new unit with the same Tr. Another new unit, but bigger to replace two existing units and a redesign in our process to optimize the refrigeration demand.
In appropriate tonnage ranges the magnetic bearing units slay the old stuff. I have a plant retrofit under construction right now with one that has a projected simple payback over rebuild of less than 3 years, and that's holding energy costs stagnant. An NLPV of just over 0.3 kw/ton can do that.
Not to mention the fact that, if you extend chiller life for another 5-7 years, will you still be able to get refrigerant for it WHEN it leaks(and it will leak)?
www.ellisconsultingengineers.com
