Automating the use of an ARX add-in in AutoCAD 2004
Hello everyone, I'm new to this section of the forum.
We have a large catalog of Medusa files that are accessible only using AutoCAD 2004 and an ARX add-in that allow the user to browse to the medusa file and import into AutoCAD.  The add-in appears to be graphical only, opening a dialog for the user to navigate to the file they wish to import.  The Medusa files are stored on that computer in a variety of folders.  We wish to script the operation of this import process to get them all in AutoCAD format and maybe also run a print-to-file step to get them in .tif format too.
The program might resemble:
- Load a list of Medusa files including full path and filenames
Loop{
 - Run import ARX, feed in next Medusa filename
 - Run print routine to dump .tif file
 - Save AutoCAD file
(end)
Is Autolisp the way to go here?  Can it automate the use of the  ARX import utility(not part of the core AutoCAD interface)?  Can Autolisp load the filenames/paths from an outside file?  Any other possible roadblocks to consider?
Thanks for any advice before I send my IT department into it.
