Solidworks - Aligned Section View longer than actual part
I am trying to make an aligned section view. However every time I finish drawing my section line the projected view is longer than the parent part. Also the view adds features that do not exist. How can I make sure the section view stays the same size and shows the actual features of the part?
RE: Solidworks - Aligned Section View longer than actual part
The regular Section View shows the "cut" as viewed in the direction of the section arrows only.
http://
If you want the regular section style, use the regular Section View.
