How do you figure the rate of sinki
How do you figure the rate of sinking for a huge caisson having W wt. 80ft down into dense sand/silt formation 100 ft below sea level while excavating inside? Since location and plumbness are necessary, what mechanical method/means would I employ to achieve the desired goal? Thanks for input.
