How to refine an axisymmetric mesh in the contact region ?
I am studying sharp indentation on a quarter cylinder corner in Abaqus and I am not satisfied with my mesh, which is currently using Tet elements (with edge seeding in the corner). I would like to use bricks (Hex element) and refine the mesh in the contact region. I already tried several solutions with the Bottom-up and "classic" mesh tools. But I don't know how to create fine transitions between each region.
I attached a picture of the partitioned mesh (with zooms on transitions) I would like to obtain.
Does anybody know how to do that ?
Thank you very much
Best,
McFly M.
RE: How to refine an axisymmetric mesh in the contact region ?
Or, you could use bias meshing, where you define a high number of elements in the contact zone and less in the areas you are not so concerned about.
Hope that helps.
My suggestion is also in line with fruton.
I model seperate parts and tie them together and use bias mesh.(mapped mesh)
thanks,
Tara
http://tinyurl.com/4ydjg7m
Thank you very much for your answers, I'd better not use different parts to avoid discontinuities but I have really been trying a lot of different options of meshing. But nothing really satisfying.
There must be a way to create the smooth transitions as seen in the attached picture in my first message. Besides, this time I attached a file where we can see the same type of (trapezoidal) elements at the transition between both regions. This figure comes from "Getting Started with ABAQUS/Standard", fig.4-43, "Mesh refined around the hole". I would like to get a similar mesh (with inverted convexity of course).
Any suggestion ?
McFly
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
Here it is. That is the model I am working with (partition + tet-mesh). What I did is I partitioned edges then faces. Then I seed Edges sets.
Thank you for your help.
McFly
1. Why not axisymmetric? I was under the impression that the loading was non-axisymmetric otherwise I would have suggested it earlier.
2. The part name is cheese are you really modeling the indention of cheese?!?
3. Since you have switched to tets you can use adaptive remeshing to refine the mesh locally based on the loading.
4. Use quadratic Tets or Hex
5. A biased edge seed appears to work well. I tried 20 global and for the 3 edges near indention bias 20 on the peripheral side and 0.5 near contact. (See image)
6. Nonlinear geometry should be used when contact or plasticity are used. It is not turned on in the preload step.
7. What does the preload step do? Is this legacy?
If I get the time I will try running this model. I hope this helps.
Rob Stupplebeen
Rob Stupplebeen
Thank you for your help. I already tried a similar mesh but I would really like to mesh with Hex.
To answer your questions
1. Indeed the load could be non-axisymmetric, that is the point of my work.
2. Cheese is just a funny name I gave to my part. (I'm french...)
3. We are not very into adaptative meshing (yet).
4. Yes, I will once I have made the initial verification of my model.
5. Well, thanks, it is good to know.
6. Ok, I will fix this. I am sorry but I don't get what the non linear geometry option does exactly. Has it something to do with large deformation?
7. I study the influence of residual stresses on indentation testing, the point of the preload step is to impose a non-axisymmetric displacement (for the moment it's just a pressure but I will fix this too).
The model is 200 times bigger than the contact region, the purpose was to avoid the boundary effects on the elastic calculations. It could be smaller using plastic.
For testing I would use a much smaller model and then determine it's sensitivity once it is up and running.
Rob Stupplebeen
Best
I am now confronted with another problem. I would like to take non-equi biaxial residual stresses into account and study their influence. Therefore I would like to subject the lateral surface of the cylinder to a displacement. I tried 2 solutions :
1) I defined 1 BC (displacement) on the lateral surface (Ux=1/Uz=1)
This is obviously incompatible with the other BCs (symmetry->no normal displacement on faces Z0Y & X0Y). So when I try to run the job I get this kind of message :
"31 nodes have dof on which velocity/displacement/acceleration/base motion etc. constraints are specified simultaneously. The nodes have been identified in node set ErrNodeBCRedundantDof." So I tried another solution :
2) I defined 2 BCs (displacements): one for Ux and the other one for Uz, I also defined 2 analytical fields so that Ux is proportional to X (and Uz to Z). This way there are no conflict between symmetry BCs and "load" BCs.
But still I get the same message. It seems that there is still a conflict in the fact that I impose the same the constraint twice at the same place.
Is there a way to avoid this ?
(I already tried to impose a pressure on the lateral surface and it worked but that is not the point of my study, unfortunately...)
MF
