ETAP 7 PV Bus
ETAP 7 PV Bus
I am new to ETAP and trying to set up a small example network. It's really small with 3 buses,i.e. one each of slack, PV and Load. The problem I have is with the generator connected to the PV bus. I tried to set to at P=60MW and V=1 p.u. Now V is correct, but P from the generator is always 0. Q is supplied OK. I have in the past used Neplan 5 and it specifically requests P and V values from the generator. Please help.
RE: ETAP 7 PV Bus
Desrod
RE: ETAP 7 PV Bus
RE: ETAP 7 PV Bus
RE: ETAP 7 PV Bus
RE: ETAP 7 PV Bus
RE: ETAP 7 PV Bus
RE: ETAP 7 PV Bus
