Buckling of beam on elastic foundation
Hi.
I'm pretty new to ABAQUS, and I'm trying to make a simple model of a cantilever on a elastic foundation. I wanted to model the foundation with springs, but can't seem to get the model to take into account the spring stiffness. I've been using this video (http://www.youtube.com/watch?v=YQLoQqinbdo) to set up my model and then added springs under engineering features.
I would expect the eigenvalues to increase when the stiffness is increased, but nothing happens.
Can someone help me with this? I've attached the file.
RE: Buckling of beam on elastic foundation
Brian
www.espcomposites.com
That's what I'm finding is working. If the values in the initial eigenvalue analysis are large, you have to change the stiffness values a lot more than you expect. For example, in my model I started with k=1 and the mode 1 eigenvalue was 2.72747e05. Changing to k=100 gave a mode 1 eigenvalue of 2.728e05.
