AWS D1.1/ASME SEXT IX- PQR Hardness Value exceeds allowable range
Base Material - ASTM A131- EH36 x 25.4mm (Thk) x Single V
Weld Process - SMAW / Weld Position - 3G-Uphill
All Mechanical Tests & Impact Testing( -20 deg celcius ) passed. But Hardness Value exceeds allowable range
Query:-
1) Is it mandatory( AWS D1.1 / ASME Sect IX )to conduct Hardness Test?
2) Does the PQR become void when hardness value exceeds allowable range?
Please share your expertise asap.
Query:-
RE: AWS D1.1/ASME SEXT IX- PQR Hardness Value exceeds allowable range
You can meet the minimum requirements of the "code", but still be in violation of your customer invoked requirements.
Best regards - Al
1. No
2. Since requirements for hardness testing are imposed by customers/owners based on their particular application, probably.
Expanding a little, most customers will say something like, PQR's must include a hardness survey performed in accordance with Sec 12.6 in API 582. They'll normally establish an upper limit, say 248 HV10, or reference another spec like NACE RP 0472. If the established value is exceeded, the PQR would not be considered acceptable for use on that project.
