ASCE 7-05 Options
ASCE 7-05 Options
When I design to ASCE 7-05 are (1)concurrent vertical seismic loads (sec 13.3), (2)Orthogonal Combination Procedure (sec 12.5.4) and (3) redundancy factor (sec 12.5.4) typically optional, only to be used when required by client specs or city/state codes.
RE: ASCE 7-05 Options
Most provisions are triggered by the Seismic Design Category of the structure. The designer may have the option to choose between a simplified or rigorous analysis method, but that is different than opting out.
