How to model a flexural beam test
I need to model a flexural test on a simply supported concrete beam with standard steel reinforcement. I have the whole test experimental data until failure and I want to create a model in Abaqus to match it. I'm concerned just about the vertical displacements and I don't care about the cracks propagation. What is the best way to model this test in Abaqus?
Thank you very much
Thank you very much
