Blind flange calculations
On a vessel we are designing we will be using a blind flange on one end. Being a novice at ASME VIII division 1, I am left uncertain as to what paragrahps I should look to when calculating whether the blind flange we have designed will be sufficient for the intended duty.
Any advice on where to look?
RE: Blind flange calculations
gr2vessels
Mike
