Outdoor Disconnect Switch
Hi there,
A quick question on disconnect switch. Can we utilize a 25kv outdoor disconnect switch on an existing 13.8kV line ? I know that 13.8kV disconnect switch exists but the client had purchased a 25kv disconnect switch instead.
Want some thoughts on that..
Sonic
Sonic
RE: Outdoor Disconnect Switch
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I'm in Canada. The ratings (i.e continuous rating (900A) & mom.asymmetrical (40kA))for the 13.8 and 25kv outdoor disconnect switch is the same. I'm under the impression that a 25kV outdoor disconnect switch can be used on an exiting 13.8kV line but would just like to get some clarifications.
Note that this is an outdoor application on a riser pole.
Thank you..Sonic
Conversion was usually done over a number of years (3-5 year). New network sections would have been built as at 25 kV naturally.
With proper ratings, there is usually no problem as mentioned by David.
Desrod
Check if there is not issues with electrical clearances or other constains.
