RT of Fillet Welds
RT of Fillet Welds
Folks,
Would appreciate your help:
Is this possible to do a RT of small bore fillet weld.
Previously I was of the impression that it is impossible to perform RT of fillet weld, however, after reading some literature I found that in most of the cases RT of fillet weld will not give you a proper indication of weld defects. Is this correct?
Secondly, If my closure weld is fillet weld, and to satisfy some jurisdiction requirements, I have to perform 100% RT in lieu of hydrotest. So how I should deal with this situation, should I go with UT for RT of fillet or any other advise would you like to give.
Thanks in advance.
Meck91
Thanks in advance.
Meck91
RE: RT of Fillet Welds
If so this might make a slight difference is required NDT inspection.
