Design Table and Reference Dimension
I'm trying to do some analysis/design work with the sketcher and I was hoping that I could speed up the process with a design table.
I am trying to have Catia output a reference dimension as I vary the angle of a tensioner. For the initial configuration, Catia would output the value of both my angles but after I add the addition rows for the first angle, the second column (reference) angle remains empty.
Is this even possible?
Thanks.
Thanks.
RE: Design Table and Reference Dimension
Derek
If you don't mind, I hope to add to your code to automate my task as much as possible.
Derek
