FindObject("PROTO#.Bodies *** in Journal VB
Hi
I´m writing on a little script , that will help me get quicker starting on a new EDM electrode part.
I use the the "Create New Parent" to create an assembly,
and the Electrode part will be the top part - and the core and cavity plate is the component.
I have made som VB tricks to automate the new name of the Electrode part. Everything works fine - but I have one problem.
In the new part I want to make a Linked Body of the component´s solid body (core or cavity plate).
In the recorded journal I have edited the "COMPONENT CavityPlatePart 1" so it is a variable of the component name.
That works 100%.
recorded journal :
>> Dim component1 As Assemblies.Component = CType(workPart.ComponentAssembly.RootComponent.FindObject("COMPONENT CavityPlatePart 1"), Assemblies.Component) <<
But, and here comes the problem.
recorded journal :
>> Dim body1 As Body = CType(component1.FindObject("PROTO#.Bodies|EXTRUDE(1)"), Body) <<
I can´t get a solution to create a variable of the component´s Solid Body name, so I can replace the EXTRUDE(1) in ("PROTO#.Bodies|EXTRUDE(1)"), with a variable.
Maybe someone here can the trick ?
lklo
That works 100%.
recorded journal :
recorded journal :
lklo
RE: FindObject("PROTO#.Bodies *** in Journal VB
Option Strict Off
Imports System
Imports NXOpen
Module FindNamedObject
Sub Main()
Dim s As Session = Session.GetSession()
Dim workPart As Part = s.Parts.Work
Dim bodies As BodyCollection = workPart.Bodies
Dim bodyname As String = "WHATEVER"
For Each b As Body In bodies
If Not b.IsBlanked Then
If b.Name = bodyname Then
b.Highlight()
End If
End If
Next
End Sub
Just change the bodyname string to whatever you might apply to the required body.
Hope this helps.
Frank Swinkels
Thank You for the answer.
But your solution in my case is not what I need.
I need to be able to create a linked body of the displayed componet( always a solid body on layer 1).
I can get the component in a variable.But not the body.
I have tried with the command DisplayableObject
but I cant figure it out.
lklo
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Utilities
Imports NXOpen.UF
Sub Main()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim obj As Body
Dim objTag As Tag = Tag.Null
ufs.Obj.CycleByName(bodyname, objTag)
If objTag <> Tag.Null Then
obj = NXObjectManager.Get(objTag)
obj.Highlight()
End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Hope this helps.
Frank Swinkels
