pressure drop filter
Is there a way to calculate the pressure drop over a basket strainer. I know that suppliers can, but I want to do some calculations in advance in Excel or something.
I assume that based on flow, viscosity, filter area and mesh widt, this should be possible. Fluids are heavy fuel oils (newtonian fluids).
DYV
RE: pressure drop filter
Depends on how much rubbish is has strained out at the time, but allow around a maximum of 25 psi loss at the design flow rate for a properly sized dirty strainer (dirty, not plugged).  Calculate K and then ratio to other flowrates using Q = K * 25^0.5
Let your acquaintances be many, but your advisors one in a thousand'  ...  Book of Ecclesiasticus
