Standard Threads
Standard Threads
Standard Threads
Hi all,
I am trying to add threads to a cylinder but when I go through the steps I am not finding anything in the Type: dropdown box in the parameter step. Any ideas?
RE: Standard Threads
I should have also said that these are straight threads, not tapered. i am looking for a 4 1/2-12 UN thread in the option box, but nothing appears.
For an internal thread - On the hole options dialog set the units to inches -you should then be able to find it.
For an external thread - on the thread parameters step set the thread units box to inches.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Thanks all. I am not sure what I did the first time but it now works.
