swdocumentmgr.dll
swdocumentmgr.dll
It appears that this file is hooking into explorer.exe when running a file search from the file open window and that causes SW to crash out without warning. Strangely enough it also crashes when do a file search from an open file explorer window as well.
Error log that is generated says;
Faulting application name: explorer.exe, version: 6.1.7601.17567, time stamp: 0x4d672ee4
Faulting module name: swdocumentmgr.dll, version: 18.5.0.128, time stamp: 0x4cf6dfd4
Exception code: 0xc0000005
Fault offset: 0x000000000001ef33
Faulting process id: 0x364
Faulting application start time: 0x01cc0a9a005cc734
Faulting application path: C:\Windows\explorer.exe
Faulting module path: C:\Program Files\Common Files\SolidWorks Shared\swdocumentmgr.dll
Report Id: d76c4693-768d-11e0-9ac7-64315018915b
I've tried repairing, re-installing, but it still crashes.
So, any hints?
Questions? ask away!
And Thanks!
So, any hints?
And Thanks!
HP Z400
Nvidia Quatro FX 1800
10 GB RAM
Quad core @ 3.06Ghz
SW2010 SP5.0
Win 7 64bit
RE: swdocumentmgr.dll
for this problem, but the suggested
fix doesn't work for everybody.
Is anyone else seeing this problem?
HP Z400
10 GB RAM
Quad core @ 3.06Ghz
SW2010 SP5.0
Win 7 64bit
Re this page:
http://he
- run this on the command line:
regsvr32 /u "C:\Program Files\Common Files\SolidWorks Shared\SwDocumentMgr.dll"
Fixed.
