Pump design for water
Any suggestions regarding industrial pump manufacturers for 3,412 cu.ft/day of water to be pumped 10' in height.
Is the pump design based on pumping once every hour?
RE: Pump design for water
18 gpm at 10 ft.
Little Giant make a variety of low cost shaded pole motor fountain/utility pumps that will meet that spec.
Hydrae
Goulds or Waterpumpsdirect have a ton of pumps that will move the amount of water you need> 18 gpm really isn't too much, you could probably pick up a pump at a local hardware store that can move that kind of water.
Bradley Dennis
Civil Engineering
http://culvertpipe.net
My upflush toilet with its macerator will do that.
