Load sensing in stack valve
If load sensing port is part of valve and is not connected to hydraulique system. will the valve sections work anyway when manually activated? Get the cylinder to extend and retract?
thanks
RE: Load sensing in stack valve
They should work, though you may have a small leak between the A and B ports. ISZ
